10 years agoA synchronous clear enable conter RTL
I have issues with RTL of simple counter: a synchronous clear enable counter.
I use Altera template to be confident as much as possible. http://quartushelp.altera.com/14.1/mergedprojects/hdl/vlog/vlog_pro_counters.htm https://www.altera.com/en_us/pdfs/literature/hb/qts/qts-qps-handbook.pdf HDL guides for counters on 12-57 I expect such counter to consist of one adder, one mux and one register, but I get two muxes if using provided template. Instead of using EN input of register second mux is implemented. How do I specify to use EN input of register? Can someone provide information on this issue? Maybe I don't understand something. I've tried to change synthesis options and it did't work. I can implement my vision of RLT with one MUX using d = a?b:c operand. But I find it kind of akward. See code below.module counter
input en, clk, rst,
output reg count,
output reg count2);
// One MUX RTL
wire new_count = rst ? 4'd0 : count + 1;
always @(posedge clk) begin
if (en) count <= new_count;
end
// Two MUX RTL (using altera template)
if (rst) count2 <= 0;
else if (en) count2 <= count2 + 1;
end
endmodule
