10 years agoA switch to detect whether a project contains a separated design partition ?
Hi, Quartus full compilation automatically run Partition Merge process if the project has a separated design partition. anyone know how quartus is able to determine whether the project has a se...
10 years agoFound. Can use [get_partition] switch to check number of partitions exists in design.
set partitions
foreach p $partitions {
if { ==1 && == "Source File"]} {
set run_partition_merge 0
} else {
set run_partition_merge 1
