10 years agoA switch to detect whether a project contains a separated design partition ?
Hi, Quartus full compilation automatically run Partition Merge process if the project has a separated design partition. anyone know how quartus is able to determine whether the project has a se...
10 years agoI usually run the following command after quartus_map:
$ quartus_cdb $qpf -c $qsf --merge=on If there are partitions, they'll be merged. If not, nothing happens. But I also would like to know if there is a check to determine if there are partitions or not.
