10 years agoA switch to detect whether a project contains a separated design partition ?
Hi, Quartus full compilation automatically run Partition Merge process if the project has a separated design partition. anyone know how quartus is able to determine whether the project has a se...
10 years agoWhat do you mean Quartus Tcl Compilation flow API? I always run "quartus_sh --flow compile <project_name>" and that mimics the pushbutton GUI flow, and will run partition merge if necessary. If that's what you're talking about that can't be run, I'm not sure of an easy way to work around it.
