10 years ago7segments verilog erorrs
hi, I'm trying to create a verilog file for 2 digit 7 segments, I've created the truth table and derive the equation using kmap but I faced a errors when analyse&synthesis :( the code is : ...
10 years ago@Galfonz, probably not. It will simply infer a LUT for each segment, which will in the end be likely not bee all that different from in resource usage than code for a ROM would use. The synthesiser is a smart beast.
@Greital, post the error messages - they will appear in the screen at the bottom of the Quartus window. If you click on the red x button it will filter and show only the errors. https://www.alteraforum.com/forum/attachment.php?attachmentid=11560
