Altera_ForumHonored Contributor11 years ago7 segment display from 4 bit binary So I understand what this is supposed to be doing in theory. However in practice I can't find any practical examples. Basically I have a circuit with two 4 bit numbers in, with a switch (S) to select...Show More
Recent DiscussionsHighlight similar instances of a selected word fails when scrollingSolvedAutomatically added negative node for TDS output doesn't work with Agilex 5Design Space Explorer - *** Fatal Error: Access Violation at 0X000000001E19EB30Tensor block usageError (169008): Can't turn on open-drain option for differential I/O pin HPS_DDR3_DQS_N[1]
