11 years agoStill results in 15 errors. Here's the full error paste up
Info: *******************************************************************
Info: Running Quartus II Analysis & Synthesis
Info: Version 9.1 Build 350 03/24/2010 Service Pack 2 SJ Web Edition
Info: Processing started: Sun Nov 09 12:46:10 2014
Info: Command: quartus_map --read_settings_files=on --write_settings_files=off test2 -c test2
Error (10500): VHDL syntax error at test2.vhd(10) near text "PROCESS"; expecting "begin", or a declaration statement
Error (10500): VHDL syntax error at test2.vhd(16) near text "=>"; expecting ";"
Error (10500): VHDL syntax error at test2.vhd(33) near text "when"; expecting "end", or "(", or an identifier ("when" is a reserved keyword), or a concurrent statement
Error (10500): VHDL syntax error at test2.vhd(34) near text "when"; expecting "end", or "(", or an identifier ("when" is a reserved keyword), or a concurrent statement
Error (10500): VHDL syntax error at test2.vhd(35) near text "when"; expecting "end", or "(", or an identifier ("when" is a reserved keyword), or a concurrent statement
Error (10500): VHDL syntax error at test2.vhd(36) near text "when"; expecting "end", or "(", or an identifier ("when" is a reserved keyword), or a concurrent statement
Error (10500): VHDL syntax error at test2.vhd(37) near text "when"; expecting "end", or "(", or an identifier ("when" is a reserved keyword), or a concurrent statement
Error (10500): VHDL syntax error at test2.vhd(38) near text "when"; expecting "end", or "(", or an identifier ("when" is a reserved keyword), or a concurrent statement
Error (10500): VHDL syntax error at test2.vhd(39) near text "when"; expecting "end", or "(", or an identifier ("when" is a reserved keyword), or a concurrent statement
Error (10500): VHDL syntax error at test2.vhd(40) near text "when"; expecting "end", or "(", or an identifier ("when" is a reserved keyword), or a concurrent statement
Error (10500): VHDL syntax error at test2.vhd(41) near text "when"; expecting "end", or "(", or an identifier ("when" is a reserved keyword), or a concurrent statement
Error (10500): VHDL syntax error at test2.vhd(43) near text "when"; expecting "end", or "(", or an identifier ("when" is a reserved keyword), or a concurrent statement
Error (10500): VHDL syntax error at test2.vhd(44) near text "CASE"; expecting ";", or an identifier ("case" is a reserved keyword), or "architecture"
Info: Found 0 design units, including 0 entities, in source file test2.vhd
Error: Quartus II Analysis & Synthesis was unsuccessful. 13 errors, 0 warnings
Error: Peak virtual memory: 231 megabytes
Error: Processing ended: Sun Nov 09 12:46:13 2014
Error: Elapsed time: 00:00:03
Error: Total CPU time (on all processors): 00:00:03
Error: Quartus II Full Compilation was unsuccessful. 15 errors, 0 warnings
