12 years ago7 Segment decoder help
Hi, I am new to VHDL and trying to create a VHDL module for a 7 segment decoder. The code I used is below
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity segementdecoder is
Port (sevenseg_A : out STD_LOGIC_VECTOR (3 downto 0);
sevenseg_C : out STD_LOGIC_VECTOR (6 downto 0);
digit : in STD_LOGIC_VECTOR (3 downto 0);
Dsel : in STD_LOGIC_VECTOR (1 downto 0));
end segementdecoder;
architecture Behavioral of segementdecoder is
signal D3 : STD_LOGIC_VECTOR (3 downto 0);
signal D2 : STD_LOGIC_VECTOR (3 downto 0);
signal D1 : STD_LOGIC_VECTOR (3 downto 0);
signal D0 : STD_LOGIC_VECTOR (3 downto 0);
begin
process ( digit )
begin
case digit is
when "0000" => sevenseg_C <= "0000001" ; --0
when "0001" => sevenseg_C <= "1001111" ; --1
when "0010" => sevenseg_C <= "0010010" ; --2
when "0011" => sevenseg_C <= "0000110" ; --3
when "0100" => sevenseg_C <= "1001100" ; --4
when "0101" => sevenseg_C <= "0100100" ; --5
when "0110" => sevenseg_C <= "0100000" ; --6
when "0111" => sevenseg_C <= "0001111" ; --7
when "1000" => sevenseg_C <= "0000000" ; --8
when "1001" => sevenseg_C <= "0000100" ; --9
when "1010" => sevenseg_C <= "0001000" ; --A
when "1011" => sevenseg_C <= "1100000" ; --B
when "1100" => sevenseg_C <= "0110001" ; --C
when "1101" => sevenseg_C <= "1000010" ; --D
when "1110" => sevenseg_C <= "0110000" ; --E
when "1111" => sevenseg_C <= "0111000" ; --F
when others => sevenseg_C <= "0111111" ; --
end case;
end process;
process (Dsel, D3, D2, D1, D0)
begin
case Dsel is
when "00" => SevenSeg_A <= "0111"; -- AN 3
digit <= D3;
when "01" => SevenSeg_A <= "1011"; -- AN 2
digit <= D2;
when "10" => SevenSeg_A <= "1101"; -- AN 1
digit <= D1;
when "11" => SevenSeg_A <= "1110"; -- AN 0
Digit <= D0;
when others => null;
end case;
end process;
end Behavioral;
When I check the syntax I get the following errorsERROR:HDLParsers:800 - "C:/Users/Alex/Desktop/VHDL/argser/dasfas.vhd" Line 51. Type of digit is incompatible with type of D3.
ERROR:HDLParsers:800 - "C:/Users/Alex/Desktop/VHDL/argser/dasfas.vhd" Line 54. Type of digit is incompatible with type of D2.
ERROR:HDLParsers:800 - "C:/Users/Alex/Desktop/VHDL/argser/dasfas.vhd" Line 57. Type of digit is incompatible with type of D1.
ERROR:HDLParsers:800 - "C:/Users/Alex/Desktop/VHDL/argser/dasfas.vhd" Line 60. Type of Digit is incompatible with type of D0. I do not understand how type of digit is incompatible with type of D3,D2,D1,D0 as they are both vectors. Can anyone advice me on how to amend the code? Thanks in advance
