16 years ago4bit adder using vhdl error 10500
hi every one
i have a problem in compiling 4bit adder using vhdl in quartus 2 10.1 cyclone 2 ep2c35f672c6 Library ieee; Use ieee.std_logic_1164.all; Entity 4bitadder is -- it is showing error here Port ( I0,I1 : in STD_LOGIC_VECTOR(3 downto 0); Cin : in STD_LOGIC; S : out STD_LOGIC_VECTOR(3 downto 0); Cout : out STD_LOGIC ); End 4bitadder; Architecture arch of 4bitadder is --it is showing error Component fulladder Port ( A,B,Cin : in std_logic; S,Cout : out std_logic ); End component; Signal Temp : STD_LOGIC_VECTOR(2 downto 0); begin FA1: fulladder port map ( A => I0(0), B => I1(0), Cin => Cin, S => S(0), Cout => Temp(0) ); FA2: fulladder port map ( A => I0(1), B => I1(1), Cin => Temp(0), S => S(1), Cout => Temp(1) ); FA3: Fulladder port map ( A => I0(2), B => I1(2), Cin => Temp(1), S => S(2), Cout => Temp(2) ); FA4: fulladder port map ( A => I0(3), B => I1(3), Cin => Temp(2), S => S(3), Cout => Cout ); End arch; wheather i have to include 1 bit adder in this or as an another file when using component instantiation please tell me that my errors are Error (10500): VHDL syntax error at 4bitadder.vhd(4) near text "4"; expecting an identifier Error (10500): VHDL syntax error at 4bitadder.vhd(14) near text "4"; expecting an identifier please help me as soon as possible.
