Rleduc
3 years ago3-Wire SPI IP Component with Arria 10
Hello dear community,
I am using Quartus Prime Pro 22.4 / Arria 10 board, and I need to implement in my QSYS design a 3 wire SPI to communicate with external ADC (AD9250). I can only find the "SPI...
- 3 years ago
Check this link https://www.intel.com/content/www/us/en/docs/programmable/683113/21-3-19-2-0/generating-the-design.html
At Example Design tab, Select Design and enable Generate 3-wire SPI module then Generate Example Design. You should see 3-wire SPI module spi_3wire.v being generated.
Sheng
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer.
Rleduc
3 years agoIt's ok I found out that I need to directly connect SDIO or any bidirectionnal port to top level IO (FPGA pin) and not through wire !
I close this topic, thanks again
