3-Wire SPI IP Component with Arria 10
- 3 years ago
Check this link https://www.intel.com/content/www/us/en/docs/programmable/683113/21-3-19-2-0/generating-the-design.html
At Example Design tab, Select Design and enable Generate 3-wire SPI module then Generate Example Design. You should see 3-wire SPI module spi_3wire.v being generated.
Sheng
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer.
Sheng
