--- Quote Start --- Hello In Verilog I got this code: cont <= 21'b0; oRST <= 1'b1; What does it mean in VHDL? --- Quote End --- In VHDL const would have to have 21 bits, eg., signal const : std_logic_vector(20 downto 0); and you'd assign all zeros to it using const <= (others => '0'); The signal oRST is a 1-bit signal, eg., signal oRST : std_logic; and you'd assign a 1 to it via oRST <= '1'; Cheers, Dave - Altera_Forum
Thanks!
Now I have in VHDL: cont <= "000000000000000000000"; oRST <= '1'; :) - Altera_Forum
--- Quote Start --- Now I have in VHDL: cont <= "000000000000000000000"; --- Quote End --- It's O.K. if you love it long-winded. You'll notice, that in Verilog also
is accepted as legal code, but giving a warning about assigning a 32 bit value to a 21 bit signal or something like that. In VHDL, the assigned constant must have the correct bit length if not using special constructs like OTHERS =>.cont <= 0;
