21.1.1 standard issues resolved, where to find the details?
The website mentions that these customer requests have been fixed in quartus prime standard 21.1.1,
Is it possible to check the details of them?
| 00501636 | 00689611 | 00675753 |
00693884 |
Kind Regards,
Alex.
- SyafieqS
Hi Alex,
Is it not possible to check all of them, but I can help to show few which you are interested to
- AEsqu
Contributor
Yes,
I just would like to know what the fixes are for the 4 above,
to see if that can impact my project.
Alex.
- SyafieqS
Understood. Let me check and get back to you for below issue.
00501636 00689611 00675753 00693884
- SyafieqS
Hi Alex,
Apologize for the longer time to response.
00501636
- In NIOS II Library Makefile the adjust-path and adjust-path-mixed functions do not handle relative paths correctly under WIndows WSL - fixed
00689611
-Intel Arria 10/Cyclone 10 Hard IP for PCI Express, Avalon-MM mode with Avalon-MM Address Width of 32-bit. Size of address pages is missing 17 to 21 bit sizes, - fixed
00675753
- Error Message Register Unloader IP cannot be generated in Quartus 21.1 Std -fixed
00693884
Root Cause: Unsupported command in hw.tcl file for the IP;
Solution: Patch 0.08std for Quartus 21.1std removes unsupported construct from hw.tcl;
https://www.intel.com/content/www/us/en/support/programmable/articles/000090380.html
This problem is tracked down to an out-of-date TCL command in the EMR unloader IP:
quartus.21.1.0-b842-ww49\ip\altera\pgm\altera_emr_unloader\altera_emr_unloader_core2\emr_unloader_core_hw.tcl:34: add_fileset_file $sdc_file SDC_ENTITY PATH $sdc_file
{NO_AUTO_INSTANCE_DISCOVERY NO_SDC_PROMOTION}
This command seems to be invalid in this version of Quartus. It should instead be:
add_fileset_file $sdc_file SDC PATH $sdc_file
- AEsqu
Contributor
Thank You for the information!
- SyafieqS
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution and give Kudos.
