21.1.1 standard issues resolved, where to find the details?
Hi Alex,
Apologize for the longer time to response.
00501636
- In NIOS II Library Makefile the adjust-path and adjust-path-mixed functions do not handle relative paths correctly under WIndows WSL - fixed
00689611
-Intel Arria 10/Cyclone 10 Hard IP for PCI Express, Avalon-MM mode with Avalon-MM Address Width of 32-bit. Size of address pages is missing 17 to 21 bit sizes, - fixed
00675753
- Error Message Register Unloader IP cannot be generated in Quartus 21.1 Std -fixed
00693884
Root Cause: Unsupported command in hw.tcl file for the IP;
Solution: Patch 0.08std for Quartus 21.1std removes unsupported construct from hw.tcl;
https://www.intel.com/content/www/us/en/support/programmable/articles/000090380.html
This problem is tracked down to an out-of-date TCL command in the EMR unloader IP:
quartus.21.1.0-b842-ww49\ip\altera\pgm\altera_emr_unloader\altera_emr_unloader_core2\emr_unloader_core_hw.tcl:34: add_fileset_file $sdc_file SDC_ENTITY PATH $sdc_file
{NO_AUTO_INSTANCE_DISCOVERY NO_SDC_PROMOTION}
This command seems to be invalid in this version of Quartus. It should instead be:
add_fileset_file $sdc_file SDC PATH $sdc_file
