15 years agoThis is an old problem with the altera tools that I raised back in Quartus 8. The problem is that the BDF files work on the same idea as AHDL rather than anything else, The VHDL conversion is a bit of a fudge. When it does work correctly it actually makes its own 2D version of std_logic, which is really annoying and backwards and no use if you want to interface to it yourself.
The only work around is going to be either write it in VHDL or break the array apart in the schematic. Altera dont really have a lot of interest in fixing the schematic.
