12 years ago
16bit pwm register in fpga
I got a task to generate 16 bit pwm register on fpga. register which should be able to generate pwm with different frequency and duty cycles.
ANYBODY help me by providing some links and datas which could give me a good start.
Thank You
1 Reply
    --- Quote Start ---
    Thank You
    --- Quote End ---
    just thought of this:
    if you use 16bit register to accumulate inc1, inc2 and flip logic of an output at overflow then assuming your ratio is a/b:
    inc1 = a/(a+b) *2^16*2*2*f/clk
    inc2 = b/(a+b)*2^16*2*2*f/clk
    you add inc1 till overflow then add inc2 till overflow and flip at each overflow.
    but check my equations are right.
