SouzanaP's avatar
SouzanaP
4 years ago
12.1sp1_243_quartus_windows
v12.0sp1 is not working (not installing) whereas v12.1 is working well.
Can you help?
  • ak6dn's avatar
    ak6dn
    Not installing under what operating system?
    You need to be very explicit what your environment is and what the error is if you expect any reasonable help.
  • SyafieqS's avatar
    SyafieqS
    Hi Souzana,
    What do you mean not able to install? Any error pop up?
    Since that version is old, you must be following the right requirement and system like os etc.
    Please do check on it.
  • SouzanaP's avatar
    SouzanaP
    Hello and thank you so much for the replies.
    We did manage to install the version, but the tool simply crashes every time we choose any particular option, for instance adding a file etc. Is this a known issue and do we have a fix for this?
  • SyafieqS's avatar
    SyafieqS
    Souzana,
    Since this is EOL Quartus it is hard to support. What device are you using?
    Is it possible to migrate latest supported device which I suggest the most.
  • SouzanaP's avatar
    SouzanaP
    Hello, We have resolved our issue. Please close the ticket. Thank you for your help.
  • SyafieqS's avatar
    SyafieqS
    p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution and give Kudos.
