11 years ago --- Quote Start --- FYI, looks like this is a cross partition boundary issue. --- Quote End --- You can test this theory by telling TimeQuest each clock is exclusive/asynchronous set_clock_groups -exclusive -group clk1 -group clk2 This stops TimeQuest from analyzing signals that cross between these two clock domains, and inherently makes you responsible for ensuring that you include synchronizers where needed. --- Quote Start --- If I new the design then I would be inclined to register the signal as docs suggest. --- Quote End --- If the example is inconsistent with the documentation, then its likely a poor example, and not worth copying further. You're better off to start with a new design, and then if you get stuck with it, post it and a simulation here, or file a Service Request with Altera. --- Quote Start --- Perhaps there is a needle-in-a-haystack fitter or synth setting to resolve. --- Quote End --- I have yet to find the "fix this poor example" button :) Cheers, Dave
