11 years ago10G Ethernet MAC Design example issue with Modelsim Altera starter edition 10.1e
I'm using Quartus II 14.0. I wanted to simulate the design example for 10G Ethernet MAC ip core. I'm following Altera Document for step by step procedure for 10G E MAC ip core Mega function user guide. when i run the do tb_run.tcl , the modelsim fails to simulate and it gives an error. ------------------------------------------------------------------------------------------------------------------------------------------------------------- # Top level modules:# altera_eth_10g_mac_xaui_eth_10g_design_example_0_eth_loopback_composed_mm_interconnect_0_rsp_mux# Model Technology ModelSim ALTERA vlog 10.1e Compiler 2013.06 Jun 12 2013# -- Compiling module altera_eth_10g_mac_xaui_eth_10g_design_example_0_eth_loopback_composed_mm_interconnect_0_rsp_demux# ** Error: (vlog-7) Failed to open library file "D:/Altera_working/altera_eth_10g_mac_xaui/altera_eth_10g_mac_xaui/simulation/mentor/libraries/rsp_demux/altera_eth_10g_mac_xaui_eth_10g_design_example_0_eth_loopback_composed_mm_interconnect_0_rsp_demux" in read/write/execute mode. # # No such file or directory. (errno = ENOENT) # ** Error: ./..//submodules/altera_eth_10g_mac_xaui_eth_10g_design_example_0_eth_loopback_composed_mm_interconnect_0_rsp_demux.sv(99): Verilog Compiler exiting# ** Error: D:/altera/14.0/modelsim_ase/win32aloem/vlog failed. # Error in macro ./tb_run.tcl line 32# D:/altera/14.0/modelsim_ase/win32aloem/vlog failed.# while executing# "vlog -sv "$QSYS_SIMDIR/submodules/altera_eth_10g_mac_xaui_eth_10g_design_example_0_eth_loopback_composed_mm_interconnect_0_rsp_demux.sv" -w..."# ("eval" body line 5)# invoked from within# "com" -------------------------------------------------------------------------------------------------------------------------------------------------------------- what could be the problem.?? Do i need to set ENV_VARIABLES for modelsim..? Please help me. thanks & regards Vinod Kumar4 Replies
Are you using the same version of Quartus and Modelsim that the design was developed with?
Yes. I'm using same version as used by Reference design document. There are two design examples in Ethernet directory. If i run simulation for "altera_eth_10g_mac_base_r" design example, simulation will work fine. If i run another design example "altera_eth_10g_mac_xaui", simulation will through error as mentioned in previous thread. what could be the reason.? Please help me to resolve this issue.? thanks and regards Vinod Kumar - Altera_Forum
Probably some files are missing. Since the other design is working fine, I would suggest you contact Altera on this.
Hi Vinod,
Just curious if you receive any resolution from Altera on this?
