SAji0
6 years ago10500 Syntax Errors
Hi All, I've been slowly knocking things out of my error list, but I'm stuck on these. Thanks in advance for any assistance. My code: library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD...
AnandRaj_S_Intel
6 years agoHi Sami,
- Include begin and end Behavioral; statements in Counterde1 entity(Line 100).
- Line 103, USE ieee.STD_LOGIC_1164.all; not USE ieee.STD_LOGIC.all;
- Line 106, use altera_mf.all; not use altera_mf;
- Line 76 space between downto 0.
Anand
library IEEE;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity freq_div is
Port( clockwide: in STD_LOGIC;
reset : in STD_LOGIC;
clock : out STD_LOGIC);
end freq_div;
architecture Behavioral of freq_div is
signal ctr_int : unsigned(25 downto 0);
signal edge_int: STD_LOGIC;
begin
process(reset, clockwide)
begin
if(reset ='0') then
ctr_int <= "00000000000000000000000000";
edge_int <= '0';
elsif rising_edge(clockwide) then
if(ctr_int= 50000000) then
edge_int <= not edge_int;
else
ctr_int <= ctr_int+ 1;
end if;
end if;
end process;
clock <= edge_int;
end Behavioral;
library IEEE;
entity tenbit_ctr is
Port(reset: in STD_LOGIC;
enable : in STD_LOGIC;
clock: in STD_LOGIC;
count_int: out STD_LOGIC_VECTOR (9 downto 0));
end tenbit_ctr;
architecture Behavioral of tenbit_ctr is
signal counter : STD_LOGIC_VECTOR(9 downto 0);
begin
process(clock, reset)
begin
if reset='0' then
counter <= "0000000000";
Elsif(clock = '0' and clock'event) then
If enable = '1' then
counter <= counter + 1;
end if;
end if;
end process;
count_int <= counter;
end Behavioral;
library IEEE;
Entity Counterde1 is
Port(CLOCK_50 : in STD_LOGIC;
KEY: in STD_LOGIC_VECTOR (3 DOWNTO 0);
SW : IN STD_LOGIC_VECTOR (9 DOWNTO 0);
LEDR : OUT STD_LOGIC_VECTOR (9 DOWNTO 0);
HEX0,HEX1,HEX2,HEX3 : out
STD_LOGIC_VECTOR(0 to 6));
end Counterde1;
architecture Behavioral of Counterde1 is
signal count_int: std_logic_vector(9 downto 0);
signal clockwide: STD_LOGIC;
signal clock : STD_LOGIC;
signal reset : STD_LOGIC;
signal enable : STD_LOGIC;
signal HEXOUT : STD_LOGIC_VECTOR (20 downto 0);
COMPONENT freq_div
Port(clockwide: in STD_LOGIC;
end COMPONENT;
COMPONENT tenbit_ctr
Port (reset : in STD_LOGIC;
clock : in STD_LOGIC;
enable :in STD_LOGIC;
count_int: out STD_LOGIC_VECTOR (9 DOWNTO 0));
end COMPONENT;
COMPONENT disp_ROM
Port( address: IN STD_LOGIC_VECTOR (9 DOWNTO 0);
clock: IN STD_LOGIC := '1';
q: OUT STD_LOGIC_VECTOR(20 DOWNTO 0));
end COMPONENT;
begin
end Behavioral;
LIBRARY ieee;
LIBRARY altera_mf;
use altera_mf.all;
ENTITY disp_ROM IS
PORT
q: OUT STD_LOGIC_VECTOR (20 DOWNTO 0)
END disp_ROM;
ARCHITECTURE SYN OF disp_ROM IS
SIGNAL sub_wire0: STD_LOGIC_VECTOR (20 DOWNTO 0);
COMPONENT altsyncram
GENERIC (
address_aclr_a: STRING;
clock_enable_input_a: STRING;
clock_enable_output_a: STRING;
init_file: STRING;
intended_device_family: STRING;
lpm_hint: STRING;
lpm_type: STRING;
numwords_a: NATURAL;
operation_mode: STRING;
outdata_aclr_a: STRING;
outdata_reg_a: STRING;
widthad_a: NATURAL;
width_a: NATURAL;
width_byteena_a: NATURAL
PORT (
address_a: IN STD_LOGIC_VECTOR (9 DOWNTO 0);
clock0: IN STD_LOGIC;
q_a: OUT STD_LOGIC_VECTOR (20 DOWNTO 0)
END COMPONENT;
BEGIN
q <= sub_wire0(20 DOWNTO 0);
altsyncram_component: altsyncram
GENERIC MAP (
address_aclr_a=> "NONE",
clock_enable_input_a=> "BYPASS",
clock_enable_output_a=> "BYPASS",
init_file=> "MULDE1.MIF",
intended_device_family=> "Cyclone II",
lpm_hint=> "ENABLE_RUNTIME_MOD=NO",
lpm_type=> "altsyncram",
numwords_a=> 1024,
operation_mode=> "ROM",
outdata_aclr_a=> "NONE",
outdata_reg_a=> "UNREGISTERED",
widthad_a=> 10,
width_a=> 21,
width_byteena_a=> 1
PORT MAP (
address_a => address,
clock0 => clock,
q_a => sub_wire0
END SYN;
