10 years ago10 tap fir filter in verilog
Hi i want to write 10 tap fir filter .also i want to generate 10 tap FIR filter usingQuartusMegaFunction. :) can you help me to write this two codes. i am beginner here.
10 years agoSorry I meant FIR compiler....:)
If you are not trying to exploit the specific structure of coefficients(like zeros in the coefficients multiplications can be avoided), FIR compiler is the ready to use use and easiest solution.
