10 years ago
1-Port ROM only outputting one byte
Hello all,
I used the Mega-Wizard in Quartus to instantiate a single clocked 1-Port ROM block, 64-bit wide, 256 words deep.
It's for a Cyclone II FPGA.
I created a Memory Initialization File to give it starting values.
Here's the beginning of it below:
DEPTH = 256; -- The size of memory in words
WIDTH = 64; -- The size of data in bits
ADDRESS_RADIX = HEX; -- The radix for address values
DATA_RADIX = HEX; -- The radix for data values
CONTENT -- start of (address : data pairs)
BEGIN
0 : 14 21 A1 4B 68 00 CA 9F;
1 : 19 D8 83 23 2B 90 28 4E;
I place the 64-bit output into a register, and send it out serially to another device, MSB first.
But when I check the serial stream, I see 00s except for the least significant byte.
So for Address 0 I see 0000000000000014 stream out, and for Address 1 I see 0000000000000019.
I don't see any warnings or errors associated with the memory after compilation.
Has anyone seen something like this before?
    How do you know its the rom and not the logic that drives the serial interface?
    Hi Awann,
    this happens if you uses spaces between the bytes. try to write all hex without spaces.
    --- Quote Start ---
    Hi Awann,
    --- Quote End ---
    Thanks Duesterberg! Problem solved.
    I swear I had seen a .mif example with spaces in between the bytes, but obviously I was incorrect.
