10 years ago1-Port ROM only outputting one byte
Hello all, I used the Mega-Wizard in Quartus to instantiate a single clocked 1-Port ROM block, 64-bit wide, 256 words deep. It's for a Cyclone II FPGA. I created a Memory Initialization Fil...
10 years ago --- Quote Start --- Hi Awann, this happens if you uses spaces between the bytes. try to write all hex without spaces. --- Quote End --- Thanks Duesterberg! Problem solved. I swear I had seen a .mif example with spaces in between the bytes, but obviously I was incorrect.
