14 years ago*** Read Me ***
Post only questions about VHDL coding in here. Also if you are working on school projects you should not ask others to do you course work for you (your professor may be watching...)
11 years agoThis should be an easy thing to do. How do you create a bdf symbol from a vhdl file. When I use the instructions stated in Altera's handbook by opening the vhdl file, clicking on file>create/update, all entires on the submenu are greyed out (not selectable). This is where you are suppose to select "create symbol from current file". What is up with this?
