Altera_ForumHonored Contributor11 years ago-O3 and --util options deprecated Hi, In the release notes (http://www.altera.com/literature/rn/rn_aocl.pdf) for 14.1, it says the -O3 and --util <N> options have been deprecated. Why? If I try to use them, the compiler ou...Show More
Recent DiscussionsHow to fix Error(23782): Failed to find an expected reportMailbox Client IP - SEND_CERTIFICATE command through FPGA fabricQuartus Prime license rehosted, unable to runFailed to run ip-setup-simulation:Connection bit order between hierarchy
