12 years ago --- Quote Start --- The one that seems to work is in the "Properties" dialog box when you select the .sof file in the "Convert Programming File" window. It's the same place where encyptions stuff is set up and specified. The other one is in "Assignments -> Device... -> Device and Pin Options..." and doesn't seem to do ... well ... anything. Thanks. --- Quote End --- That's right, I also notced that in Quartus 12.1. "Properties" dialog box when you select the .sof file in the "Convert Programming File" window is working and "Assignments -> Device... -> Device and Pin Options..." is not.
