12 years ago --- Quote Start --- Compression is not really enabled by default. --- Quote End --- Thanks for the pointer. There are, annoyingly, two compression checkboxes. The one that seems to work is in the "Properties" dialog box when you select the .sof file in the "Convert Programming File" window. It's the same place where encyptions stuff is set up and specified. The other one is in "Assignments -> Device... -> Device and Pin Options..." and doesn't seem to do ... well ... anything. Thanks.
