12 years agoAccording to the datasheet (http://www.altera.com/literature/hb/arria-v/av_51002.pdf), page 56, the configuration data for this FPGA is 185,915,648 bits, so your file size seem right. You should enable file compression to fit it in your configuration component. It's strange, I thought it was enabled by default.
