14 years ago# Invalid time string specified: in ModelSim
I'm using ModelSim Altera Starter Edition 6.6 for simulating some very simple designs. I started a new project, compiled and everything was ok. But when I had wanted to start simulation, I have opene...
14 years ago --- Quote Start --- Try the modelsim simulation I sent you the link to. See if that works. --- Quote End --- I used your simulation, just as it was described on the readme file, and got the grey wave window all over again. --- Quote Start --- That'll at least tell you the tools are setup ok. --- Quote End --- So the problem probably isn't the code, but the tools?
