8 years ago
*** Fatal Error: Access Violation at 0X000000005DD8C080
I have a board with Altera CycloneIII EP3C40F780C7N FPGA installed and Numonyx StrataFlash 4400P0VB0E attached.
All the time when I try to save downloaded flash image (examine) over Quartus Programmer it shows the issue - *** Fatal Error: Access Violation at 0X000000005DD8C080
Could you please advise what could be the cause of the problem?
Quartus II 64-bit version 13.0.1 Build 232 06/12/2013 SJ Web Edition used.
below is the trace:
Module: quartus.exe
Stack Trace:
0x3c07f: memcpy + 0x11f
0x13963: PGMIO_PCF_FILE_INFO::get_prog_mode_mask + 0x153
0x4359c: PGM_CHAIN_ELEMENT::create_flash_map_from_bitfield + 0x6bc
0x5fc0f: pgmwq_select_hardware_and_close + 0x796f
0x6adc9: pgmwq_select_hardware_and_close + 0x12b29
0x6e066: pgmwq_export_device_dlg + 0x1a76
0x784a4: pgmwq_export_device_dlg + 0xbeb4
0x11eb5a: QMetaObject::activate + 0x53a
0xdd2f: QAction::activate + 0xdf
0x3b3447: QMenu::findIdForAction + 0x327
0x3b9c21: QMenu::internalDelayedPopup + 0x8c1
0x6a164: QWidget::event + 0xd4
0x3b9fb2: QMenu::event + 0x2a2
0x228f5: QApplicationPrivate::notify_helper + 0xf5
0x241ab: QApplication::notify + 0x70b
0x10a7c1: QCoreApplication::notifyInternal + 0x71
0x2371c: QApplicationPrivate::sendMouseEvent + 0x1ec
0x812ba: QApplication::winFocus + 0x9da
0x83f4c: QApplication::restoreOverrideCursor + 0x93c
0xbc4f: CallWindowProcW + 0x4cf
0xb5ce: DispatchMessageW + 0x1ae
0x132f69: QEventDispatcherWin32::processEvents + 0x3b9
0x83564: QApplicationPrivate::translateTouchEvent + 0x884
0x109cf0: QEventLoop::exec + 0x230
0x3b8006: QMenu::exec + 0x76
0x6a5f0: QWidget::event + 0x560
0x380d06: QFrame::event + 0x36
0x46ae14: QAbstractItemView::viewportEvent + 0x4b4
0x10a932: QCoreApplicationPrivate::sendThroughObjectEventFilters + 0x82
0x228e1: QApplicationPrivate::notify_helper + 0xe1
0x24556: QApplication::notify + 0xab6
0x816a4: QApplication::winFocus + 0xdc4
0x10e5ff: QCoreApplication::exec + 0xdf
0x4c78: msg_exe_fini + 0x58
0x53bc: msg_exe_fini + 0x79c
0x1584: MEM_SEGMENT_INTERNAL::~MEM_SEGMENT_INTERNAL + 0x194
0x5f9f: msg_exe_main + 0x8f
0x12773: BaseThreadInitThunk + 0x13
0x70d50: RtlUserThreadStart + 0x20
End-trace
Quartus II 64-Bit Version 13.0.1 Build 232 06/12/2013 SJ Web Edition
Service Pack Installed: 1
    Tried today Quartus and Programmer Pro version 17.1 - the same issue (didn't help)...
  • butterdog's avatar
    butterdog
    I have the same problem as you. Has the problem been solved?
