WWeww
7 years ago我的电脑内存现在是32GB的,但是A10系列芯片在Quartus17.0 Prime Standard版本上编译的时候,总是出现Error (114016): Out of memory in module quartus_map.exe (47657 megabytes used) 这样的错误,请问要怎么解决?谢谢。
CalvinJoaz_P_Intel
Contributor
7 years agoHi WWeww,
You getting this error message is because the available memory in your machine is insufficient to continue running or to perform the specified operation.
Which device you're using?
Kindly refer below link for recommended physical RAM for Arria 10 devices - Page 2
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/rn/rn_qts_dev_support.pdf
Thank you.
