10 years agoYet Another TSE/SGDMA/Simple Socket Server Post
Hello Altera Forums! I have been a long time lurker, and am making my first post. I have been searching for my particular issue, but that has not yielded any specifically useful results. Let me...
10 years ago --- Quote Start --- Glad to know it works, even if I didn't have anything to do with that! Did you set up timing constraints for the RGMII I/O pins? If putting a ddio for the clock line it could indicate a timing issue. I didn't think it would matter for a 25MHz clock, but maybe it does after all. --- Quote End --- I did not setup any constraints on the RGMII pins specifically, I assumed that the TSE files had something in there for them. Perhaps that was a bad assumption. I got the idea of the GTX clock DDIO from the DE2-115 Dev Kit Web Server Example. They do the same exact thing there, shifting the output clock by (~1.5ns).
