10 years agoYet Another TSE/SGDMA/Simple Socket Server Post
Hello Altera Forums! I have been a long time lurker, and am making my first post. I have been searching for my particular issue, but that has not yielded any specifically useful results. Let me...
10 years agoDaixiwen,
Correct, that packet capture was from SignalTap, not the actual NIC. And yes both the board and PC are in 100Mbps mode. I do have good and bad news however. Yesterday I was able to get the SSS running! Ping/Telnet both worked flawlessly. I powered it down, powered it back up and reprogrammed and it still worked. Then after I disconnected the ethernet cable and tried to reconnect to it, it stopped working. I haven't been able to get it working again since then. How is it possible that I could fully power off, power on, reprogram, then run the SSS successfully twice then have it not work on subsequent tries? I'm a bit confused.
