16 years ago
Writting floating point numbers using IOWR IORD
I'm trying to read a custom register which has a 32 bit floating point value, from the NIOS in the c-code using the Macro IORD(base,offset).
If I assign this to a variable defined as float and Add it with 2.
And write the result into another custom register using IOWR Macro.
I'm not getting equivalent IEEE-754 value in the register.
Can anybody suggest what might be the problem?
Code is as below:
float x,v;
x= IORD(IOREG_BASE,0); // Reading from the register1 defined in H/W
v= x+2;
IOWR(IOREG_BASE,1,v); // Writing to register2 defined in H/W
