16 years agoWritting floating point numbers using IOWR IORD
Hi, I'm trying to read a custom register which has a 32 bit floating point value, from the NIOS in the c-code using the Macro IORD(base,offset). If I assign this to a variable defined as flo...
16 years ago --- Quote Start --- This should probably work on any relatively standard C compiler. --- Quote End --- Only when sizeof float == 4.
