15 years agoWorst slack values are Negative for Removal
HI , I am trying to run the NIOSII example of led from the nios2 hardware manual.I could generate the nios 2 system.And also integrate it with the Quartus.But when I compile the system in quart...
15 years agoHI,
In the same tutorial I was able to run the code on the leds but the software does not respond to the lcd or the 7 segment display on the board.I dont see the output there though I can see them on the console while debugging Can anyone tell why is this happening? I am using cyclone3 development board.
