15 years agoWorst slack values are Negative for Removal
HI , I am trying to run the NIOSII example of led from the nios2 hardware manual.I could generate the nios 2 system.And also integrate it with the Quartus.But when I compile the system in quart...
15 years agoaltera_reserved_tck is the JTAG clock and it is present in your system if you use the Nios II debugger, JTAG UART, Signaltap II, etc...
If you select the failing path as shown in Timequest and copy and paste it into a post you'll probably get better information out of us....
