15 years agoWorst slack values are Negative for Removal
HI , I am trying to run the NIOSII example of led from the nios2 hardware manual.I could generate the nios 2 system.And also integrate it with the Quartus.But when I compile the system in quart...
15 years agoRecovery and removal are basically the same as setup and hold, but for asynchronous signals. (At least that's what I learned in my Time Quest lesson, someone correct me if i'm wrong).
I also learned, that you normally don't care about altera_reserved_*, as there's nothing you can do about it.
