15 years agoWorst slack values are Negative for Removal
HI , I am trying to run the NIOSII example of led from the nios2 hardware manual.I could generate the nios 2 system.And also integrate it with the Quartus.But when I compile the system in quart...
15 years agoHey thnks mcr42..
But can you explain what in specific is worst case slack for recovery and removal.The one which I am getting as negative in this design are Worst case slack for: altera reserved tck : removal Design wide TNS :altera reserved tck :removal What are the removal and the recovery timings for ?I am aware with the setup and the hold timings. Thanks!!!
