15 years agoWorst slack values are Negative for Removal
HI , I am trying to run the NIOSII example of led from the nios2 hardware manual.I could generate the nios 2 system.And also integrate it with the Quartus.But when I compile the system in quart...
15 years agoTimequest estimates timing values for corner cases (at least it should if configured correctly).
So if your timing fails, it will fail at -40°C or at 100°C (or whatever corner case is defined). It will probably work on your desk, but when deployed to the field it might fail occasionally, or regularly, depending on the amount of bad luck you have.
