15 years agoWorst slack values are Negative for Removal
HI , I am trying to run the NIOSII example of led from the nios2 hardware manual.I could generate the nios 2 system.And also integrate it with the Quartus.But when I compile the system in quart...
15 years agoInstead of create_clock you could use
"derive_pll_clocks -create_base_clocks" With this Timequest should read the values from the PLL and SOPC.
