15 years agoWorst slack values are Negative for Removal
HI , I am trying to run the NIOSII example of led from the nios2 hardware manual.I could generate the nios 2 system.And also integrate it with the Quartus.But when I compile the system in quart...
15 years agoWell, you can always reduce the frequency by adding a pll in the clock path.
It might be that just adding a pll already fixes your problem, but if timing already fails at 50MHz, something in your design seems really off. I usually define every altera_reserved_* as false path, but that might not help you just yet.
