21 years ago
wishbone - avalon
Hellu,
I want to interface a master wishbone interface to an avalon interface, can somebody tell me how should I connect the control signals such as
STB,CYC,WE,ACK,RTY ... to an avalon bus ?. I am OK for data , address and clock but not for the rest !.
thank u all. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif
1 Reply
    Hi gregoryw,
    Avalon read and write signals can be derived from wb cyc, stb, and we.
    Use the (cyc & stb) to qualify the cycle and we to drive either read or write.
    Unless your wb master is the only master for a particular slave, you&#39;ll need
    to add some logic to handle the ACK -- which is basically the opposite of the
    avalon ready ... since you&#39;ll have to wait for the avalon arbiter to grant your
    master access.
    Avalon slaves don&#39;t generate retries ... so you can just negate the RTY signal.
    You should carefully review the Wishbone Bus Specification though. It&#39;s all there
    and you&#39;ll save yourself lots of headaches if you spend a few hours reading it ;-)
    --Scott
