DXu2
6 years agowindow10 Quartus pro 19.2 软件nio2 command shell 无法启动?
我下载的文件:eclipse-cpp-2019-06-R-win32-x86_64 我的安装指令: Extract the downloaded file into this directory: < Intel® Quartus® Prime installation directory>/nios2eds/bin. You should see the < Intel® Quartus...
MEIYAN_L_Intel
6 years agoHi,
Its seems the error is same as thsi forum:
https://forums.intel.com/s/question/0D50P00004NtxB8SAJ/quartus-prime-pro-192-nios-ii-command-shell-and-nios-ii-sbt-for-eclipse-are-not-working-under-windows-10-pro-1903
I had with ticket: 1507321697 as mentioned in this forum, the developer is still investigating this problem.
Could you try to install "Quartus from the installation 19.2 and the Nios II SBT from the installation 18.1"?
