10 years agoWhy need specify Memory initialization file for running Nios ii in Modelsim
Hi, I am new on simulation using Modelsim. According to altera Quartus software handbook (under the section running Nios ii system with modelsim), the document stated that " to run a Qsys generated ...
10 years agoTypically your NIOS code will reside in an on-chip memory. You set the processor reset and interrupt addresses to be in that on-chip memory. I'd recommend an LED blink program rather than hello, world as it's easier to verify your results. Follow a tutorial that blinks LEDs. I don't think a console will work in simulation other than seeing logic levels of the RS232 wire. There is a utility somewhere that you will need to run to convert your software binary to mif format for use in the sim. Sorry but I don't remember what it is called.
