10 years agoWhy need specify Memory initialization file for running Nios ii in Modelsim
Hi, I am new on simulation using Modelsim. According to altera Quartus software handbook (under the section running Nios ii system with modelsim), the document stated that " to run a Qsys generated ...
10 years agoThanks for the information Galfonz.
Between, for example, I wish to run the simple hello word program. Is it mean that the memory initialization file helps to put the code into the memory so that the processor is able to process the hello world.c?
