11 years agoWhy is my software not producing the correct Avalon write?
I have my nios connected to an Avalon memory mapped bridge that will allow me to communicate with an external RTL component. All I am trying to do is read and write to a register in the RTL component...
11 years agoDid you connect your custom component within Qsys or the bridge is exported? Are you using Avalon-MM pipeline bridge?
I hope that you did not export the bridge directly. Can you share you Qsys system design/address map?
