16 years agoWhy I can't see SRAM when selecting reset&exception memory location?
My board has a SRAM on it. So I tried to use it in NIOS II. From ftp://ftp.altera.com/up/pub/university_program_ip_cores/90 , I got a SRAM_Controller code to interface the SRAM to Avalon bus. H...
16 years ago --- Quote Start --- If above does not help, make sure that in the .tcl-file of the component there is following line: set_interface_property avalon_slave_xxx isMemoryDevice true --- Quote End --- Thanks. This method works. Now I can run download software to SRAM and run it.
