11 years agoWhy does an output only 8-bit wide PIO use/needs 16 memory locations (0x2010-0x201F)?
Hi all, I'm new to the Nios/Qsys/Eclipse. I've used Quartus software before but never with Nios. I'm using a Nios Gen2 with a MAX10 (BeMicroMAX10). The free version of Nios. The bas...
10 years ago --- Quote Start --- You should also make your slave 32bits wide - return 0 to reads for the top 24 bits. The Nios acceses are 32bit (with appropriate byte enables for writes) and logic gets added to generate 4 cycles to an 8bit slave. --- Quote End --- Do You suggest to make all PIO registers ( connected to NIOS II as slaves in QSys ) 32-bits wide even though only several bits are used? What C type variable should then be used? Apparently, unsigned int ?
