21 years agowhy cann't it recive interrupt
why cann't it recive interrupt,when the key is pressed, the led shows nothing
# include "system.h"# include "altera_avalon_pio_regs.h"# include "alt_types.h"# include "D:\document\nios\low_cost\h\alt_irq.h"# include <stdio.h># include <unistd.h> volatile int edge_capture; static void handle_button_interrupts(void* context, alt_u32 id) { volatile int* edge_capture_ptr = (volatile int*) context; *edge_capture_ptr = IORD_ALTERA_AVALON_PIO_EDGE_CAP(BUTTON_PIO_BASE); IOWR_ALTERA_AVALON_PIO_EDGE_CAP(BUTTON_PIO_BASE, 0); } static void init_button_pio() { void* edge_capture_ptr = (void*) &edge_capture; /* Enable all 4 button interrupts. */ IOWR_ALTERA_AVALON_PIO_IRQ_MASK(BUTTON_PIO_BASE, 0xf); /* Reset the edge capture register. */ IOWR_ALTERA_AVALON_PIO_EDGE_CAP(BUTTON_PIO_BASE, 0x0); /* Register the interrupt handler. */ alt_irq_register( BUTTON_PIO_IRQ, edge_capture_ptr, handle_button_interrupts ); } int main (void) { IOWR_ALTERA_AVALON_PIO_DATA(LED_PIO_BASE, 0); # ifdef BUTTON_PIO_BASE init_button_pio();# endif // while( 1 ) { if (edge_capture != 0) { IOWR_ALTERA_AVALON_PIO_DATA(LED_PIO_BASE, 0xf); } } return 0; }5 Replies
help me
Which design (Quartus) are you using?
If you take a look at a Nios reference design like standard or full, there are interupt buttons as well. Then if you look at the board diagnostic software example you'll see how the buttons are handled.
1. I use quartus
// 2. I refred to the software example,but the button can not handled. // 3. is my program error ???? - Altera_Forum
I have the same problem
my system consists of button_pio led_pio onchip_ram the capture register can catch the rising edge and capture's value can change but the interrup funtionstatic void handle_button_interrupts(void* context, alt_u32 id) can not respone i need help thank!!!!!!
